Formal ProNitro 80.19 specs?
Tx76
Hello there!
I could probably get a Formac ProNitro 80.19 Nubus video card and I‘m looking for its specs.
I would especially like to know if it can drive an Apple 12“ RGB Display.
I googled thoroughly but didn’t find anything…
Does anybody know this card?
Thanks!
Hello there!
Thanks!
Generally this era of Formac card came with a monitor and did a single resolution, that will be the wrong resolution for a 12" display.
@Bolle - let me know if I'm mistaken on this one?
Tx76
OK, thanks a lot!
Do you happen to know which resolution that is?
Would the monitor have the same name? I will look it up.
OK, thanks a lot!
1024x768 I think.
The monitor should be called a Pronitron 80/19. I'd say the same thing, but I think the card might technically have another name.
