superjer2000
@cheesestraws - Force32 is awesome and saves a fair bit of time fiddling around with PRAM-battery-less Macs.
I know the Github page indicates that the extension doesn't check for 32-bit addressing capability but it would be awesome if if would check the gestalt ID and not do it's magic if it's on any of the 68000 Macs -
I was using the same external boot drive today on my SE that I normally use with my SE/30 and Force32 restarted the SE. I am assuming that it would keep restarting since it wouldn't be able to activate 32 bit addressing?
Again, not sure if this is an easy change or not but I thought I'd submit this feature request and see what happens!
