mg.man
Hey, so, are you still after more measurements? I'm working on another B&W G3 and have the side panel off....Don't worry about it. It won't be hard to get.
If the side panel off, I would be very happy to have exact height of the letters. Millimetres is fine.Hey, so, are you still after more measurements? I'm working on another B&W G3 and have the side panel off....
I know a guy called BigG...Don't have anything super sophisticated, but I'm calling it 12cm.
Also, I have a tape that is 1 chain long, divided into yards and links. I should have loaned you that to take the measurements for our American friends.Don't have anything super sophisticated, but I'm calling it 12cm.
An ounce is an ounce, but a pint and a gallon are certainly NOT the same. There are, however, 8 pints in each of the latter. (US or UK gallon)They seem to use different values for everything else like gallons and pounds.
I think so, but if you need one Cup of something you must first define it as a solid or liquid. The measurement is the same but not the instrument >_<Also, I have a tape that is 1 chain long, divided into yards and links. I should have loaned you that to take the measurements for our American friends.
US standard imperial metric freedom inches are the same as British inches aren't they? They seem to use different values for everything else like gallons and pounds.
Surely you just use bushels?I think so, but if you need one Cup of something you must first define it as a solid or liquid. The measurement is the same but not the instrument >_<
(Weird fact, lots of fruit is still sold wholesale in bushels, but given as a weight, it's why the 'standard' boxes vary between types of fruit between like, ~10kg, 12kg, 15kg etc)Surely you just use bushels?
12cm is good for me. Thanks again.Don't have anything super sophisticated, but I'm calling it 12cm.
What... like inches in a foot? Or minutes in an hour?The Imperial System would have so much to recommend if it had chosen a common multiplier like 12 or 60.
Yes, but consistently.What... like inches in a foot? Or minutes in an hour?
A person 43 milliHelens in beauty has the amount of beauty required to have 43 ships launched to save said person.
I see your kilomacs and raise you to 'Percentage of Dwelling Left Unfilled by Macs'.My collection, therefore, is approximately 63.75 kiloMacs.
