Here's my process:
-download a..hqx or .bin off the internet
-use HFVExplorer to copy into a working virtual hard disk (.hfv) that has been installed properly with System 7.5.3
[SIZE=1.4rem].....[/SIZE]
[SIZE=1.4rem]-Copy the contents of the extracted image disk to a physical 1.44 mb mac formatted disk through a USB disk drive[/SIZE]
-Bring the disk over and profit!
I am doing something similar...
For some reason, I didn't think of using the floppy directly in HFVExplorer.
I've just been taking the disk image I am using in mini vMac and writing that image to a USB floppy.
Currenty, my USB floppy drive (I got it cheap on e-bay) doesn't work in Windows 10 as a floppy. (if I put a formatted FAT disk in there, Windows won't see it.)
But it works fine for me to write images to... (Which is all I really got it for anyway.) I'll try it in HFVExplorer with a Mac formatted floppy and see what it does.
Sometimes, I don't need HFVExplorer, as I can copy the files directly to mini vMac (using importfl).
But that doesn't always seem to work for me. It copies the files, but I can't always expand them.
I think it has to do with the embedded file associations. (SIT!, SITx, etc.) I am still working on getting a handle on those. ;-)
I did think about using my Kryoflux to do this early on, but that process is NOT simple. And Kryoflux and Win10 are tricky to keep happy together.
desiv
