Classicman
Hi dear friends!
I recovered a Newton eMate 300 with its original power supply through a friend of mine. It's fantastic!!!
I can define the cosmetic condition as being like new!
But... connected to electricity it shows no sign of life... nothing... not even its green LED lights up.
I can tell you that I checked its power supply with a multimeter that it correctly delivers its 7.3/7.4 volts.
I also removed its internal battery pack (NiMH) because I think it is definitely exhausted but nothing, nothing changes.
I even held down its little "reset" button on the bottom of the chassis but nothing.
I researched on the web about this model of Newton, and I noticed that on its logic board there are no electrolytic caps which over time can lose the much feared electrolyte.
This "apparent death" should not be due to capacitors of this type...
Before starting to disassemble the very delicate bondi plastic of its chassis, can anyone help me with some tips? do I need to check something specific?
I thank you all in adavence!
