This is incorrect. MFS and HFS are both well supported by System 6; HFS support was supplied in the ROM of the Mac Plus (wikipedia). HFS is readable and writable on Mac OS X from 10.0 to 10.5, before the support for writing to HFS disks was dropped in 10.6.[...] if it is an HFS volume inside, they can be mounted and read (not written) by hdiutil, however vintage 68k macs with OS6 can't read those volumes.
I run Mac OS X 10.5 with MFS Lives! filesystem kernel extension so I can mount MFS and HFS disks using DiskImageMounter. MFS is read-only with this OS X kernel fs extension, so I use mini vMac if I need to modify MFS disk images.Hi forum, does anyone know how I might create, read, and write raw floppy .dsk files (as used by Floppy Emy) on a modern Mac?
Appreciate the confusion. I don't mean mounting on the vintage mac. I mean mounting an image on a modern mac. I can read and write from and to using Floppy Emu through to the disk images on the sd card, but I am looking for an easy way to move vintage files to and from those disk images (on the sd card or other modern media). When I say "easy" I mean a piece of software to do the transfer rather than going through Windows, Linux, emulators, etc.I'm confused about this conclusion:
You might be confusing "HFS" with HFS+ aka HFS Extended, which was introduced in Mac OS 8.1 with some limitations.
Are you using a Mac 128k? That would be the only situation where you need to transfer data as MFS back and forth between your Macs, which is a fair bit more tricky than the HFS route. Otherwise HFS is probably what you want.
