dcr
Okay, first, I am trying this in the Virtual ][ emulator and not on an actual Apple IIe. But, I think it should function pretty much the same.
I have a program on a (virtual) diskette. I can use "LOAD filename" to load the program into memory and then "LIST" will show the program. But, it scrolls through until the end with no pauses. Wasn't there a command that would fill the screen and then pause to wait for a keypress before showing the next portion? That way, you could go through the code one screen at a time instead of running through the whole thing and only seeing the end.
I've searched online but the sites I've found don't even show the LIST command.
Sad thing is that I used to have these things memorized and could fly through stuff with the keyboard commands.
