Death chimes - any guide?
stormy
Hi guys,
I have a pb 190 which when turned on does the regular Apple 'good' boot chime, then after a little while (I think after it counts the ram because the time changes depending on whether I have the extra ram installed or not) it does a very slow death chimes, reaaallly slowely. No screen output at all.
Any suggestions on possible faults? Thanks
3lectr1cPPC
I would try to remove the hard drive. I’ve had a bad boot partition cause a death chime, but I still got a display so there might be move than one issue if the hard drive is the cause of the death chime.
stormy
This is the exact problem:
Does anyone have any suggestions? I've re-capped all the electrolytics and tested all the tantalums for shorts...
desertrout
This may sound cliché, but have you recapped the logic board? Doing so resolved boot issues on my 190cs...
