ClassicHasClass
In a recent thread I mentioned I'd whipped up a proof-of-concept for a self-hosted proxy wherein the Mac would pull down web pages, preparse them, and then hand them to your browser of choice as a proxy. For example, you could strip JavaScript this way so that Netscape Navigator wouldn't have a snit fit, and you wouldn't be cheating by running the proxy off some larger more powerful system somewhere else. If you can't fix the browser, fix its input.
So here is that proof-of-concept:
http://www.floodgap.com/software/copperweb/
Note that this turned out to be a lot to ask from a 68K, even considering the overhead of Perl. Especially on MacOS, the browser can steal cycles from the proxy, starving itself for data (this is fortunately much better on A/UX) and the MacOS version doesn't work properly with all browsers for reasons I probably can't fix. On the whole, the whole shooting match drags things down to about two or three times slower, but it can access stuff it could never access before, so it may well be worth it.
There are both A/UX and System 7 versions. The A/UX version runs "conventionally" from CommandShell; the MacOS version uses MacPerl 4.1.8 (you can get a binary from the page too if you don't have one). Read the directions carefully as it's a bit finicky and there are quite a few drawbacks to consider.
As they say, it's not that the dog walked well. Comments (and patches especially) solicited.
