LaPorta
That won't work on a period Mac with OS 9.Change .dsk to .img and mount using FuseHFS.
https://github.com/thejoelpatrol/fusehfs
Thesc-clc.mov.256
contains some resources that are missing fromsc-clc2.mov.256
Thesc-clc.mov.256
I think the version of QuickTime on the emulated Mac OS 9 computer will do this once you register it with a Pro key and open up the export options.But when I export them to a modern Mac (using an emulated OS 9.0 computer from infinitemac.org), QuickTime Player doesn't recognize the files and won't play them.
Of course, in Mac OS 9 you would just drag the .img onto the Disk Copy window.That won't work on a period Mac with OS 9.
Yes, but Disk Copy won't open those .dsk images.Of course, in Mac OS 9 you would just drag the .img onto the Disk Copy window.
In an emulator, you could copy the small disk images onto a big disk image and include the big disk image as a disk or you can have the emulator include all the disks.
Nice! Will it save as an MP4 or DV stream, though? I would think it would predate all of that.Btw you don‘t need QuickTime Pro to convert movies. Just get the MoviePlayer app of QuickTime 2 (?) which contains all/most pro features.
It will save it as DV! Just tried it using MoviePlayer 2.5 and QuickTime 4 on Mac OS 9.1Nice! Will it save as an MP4 or DV stream, though? I would think it would predate all of that.
No need to recompress. You can retain the QuickTime MOV container and video data as-is. You need to merge the data from the resource fork into the data fork. Once you have a proper MOV container file, modern tools like VLC and ffmpeg should be able to process the files. I don't suggest recompressing due to the low resolution and small size of these files, best to leave them as-is.
See: https://stackoverflow.com/questions/67873319/merge-mac-resource-fork-into-quicktime-file
GitHub - mivk/qt-unfork: Flatten old Quicktime movies which use a separate resource fork for the moov atom
Flatten old Quicktime movies which use a separate resource fork for the moov atom - mivk/qt-unforkgithub.com
I see. So to avoid re-encoding the original video, basically you would use QuickTime 7's "save as self-contained movie" option, rather than converting it to MP4 or AVI.
Just drag the .dsk file to the Disk Copy application window.Yes, but Disk Copy won't open those .dsk images.
