johnklos
There has been much discussion about ways to get CompactFlash cards onto SCSI busses. Some machines can take a full height 3.5" drive or another option is putting something in place of a CD drive, so SCSI-IDE adapters like the ARS-2000FU (which mounts underneath an IDE drive and makes it full height) or the AEC-7720U (which mounts behind and can fit with the drive in the space of a CD drive) viable options. IDE to CF can then be added.
The Quadra 605 obviously has no space for either of these. One option (which I did for a few years) was to remove the floppy drive and run cables from the motherboard and the hard drive to an AEC-7720U which was in the space of the floppy as shown here:
http://www.mac68k.org/~john/boobookitty/
That hard drive died. I've had this machine since my friend gave it to me (and she bought it brand new) so it's outlasted many drives. So instead of replacing the IDE drive, I got a SCSI-SATA enclosure (the Acard ARS-2000SU) and installed a 250 gig laptop hard drive. Using less power and generating less heat is always good, plus I could keep it more original with the floppy still installed. Needless to say, after a few years that hard drive died, too. So I decided to go the CompactFlash route.
Using an expensive ARS-2000SU might seem like overkill for attaching a CompactFlash card, and the AEC-7720U is still an option with an Addonics CF-IDE adapter, but I really like how the ARS-2000SU fits so perfectly, so I got a SATA-CompactFlash adapter:
http://www.amazon.com/gp/product/B0036DDXUW
and a CompactFlash-SD adapter:
http://www.amazon.com/gp/product/B0016G8DBA
and a 64 gig SD card, but either the SD card or the adapter made that too slow, so I got a regular 16 gig CompactFlash card and it's been running quickly and smoothly ever since:
I already upgraded the VRAM from 512K to 1 meg and I may get a 64 gig card, so hopefully I can consider this machine finished for a good number of years.
