From reading many forum posts, it seems that the Color Classic is just a difficult machine to get working. I recently repaired a dead Macintosh Color Classic. When I first opened the motherboard tray, I thought that it was missing ram SIMMS and a processor. After research, I realized that there was built-in ram (additional SIMMS can be added -hence the empty slots), and I was only missing an optional co-processor. When I plugged the Macintosh into the wall, flipped the switch and attempted to turn it on by pressing the keyboard's power button, nothing happened. I then cleaned and re-capped the entire motherboard. (The attached picture shows the analog board which probably does not need to have its capacitors replaced yet) This still did not fix the computer. The computer only turned on when I inserted a fresh PRAM battery. With a battery installed and the system re-capped, the computer booted instantly and began operating normally. It now turns on and off -operating reliably just as any other restored Macintosh does.
