Color of a Mac 128k?
snuci
I just saw a Buyer's Guide for Macintosh book on eBay from Winter of 1984.  On the cover is a picture of a Macintosh.  It looks to be quite dark already.  I've seen pictures of much lighter ones and assumed that darker pictures meant they were darkened by light but now I'm wondering.
Is this an accurate color for a Mac?  It can't be old.
The auction with other pictures is here:  http://www.ebay.ca/itm/141929997836
sstaylor
Apple started out with a sort of beige color, and later moved to what they called "platinum", which was lighter.  You can see the transition with the Plus, some of which are beige and later ones platinum.  The color on the cover looks pretty accurate.
unity
Well Apple moved from beige to snow white to platinum to be exact. But the Mac went from beige to snow white. I have that same guide, its pretty common. Dont judge a Mac by its cover, they are a little dark on there.
But lets back up a sec. A thousand things can impact the color of the Mac. Lighting alone has a huge impact. Also they can yellow a bit making them seem a little darker. And in this case, its not an actual product but a magazine cover in gloss printed on hard stock.
Here is an example of a Mac I have. All I did was change the color temperature of the photo, something cameras do internally based on surrounding light. So depending on how this Mac was shot, it could look like beige or platinum.
By the way, if you really want a mind trip the compact displays are not really white, they are blue. That is why in photographs they appear more blue than anything. Because of teh refresh rate and the way the eye works, they appear white - which in the end was the intent.
olePigeon
128k, 512k, and Apple II through revision A //e should all be Pantone 453.
Which Pantone 453, I couldn't say.  If I had to guess, 453U for painted plastics (such as the early Apple IIs), and PQ-453U for the machines with colored plastics (early Macintosh, revision B //e.)
Some fun history on the color:  http://apple2history.org/2012/02/10/pantone-453/
Mac128
Need to nip this one in the bud. There is no "Snow White" color. That refers to the name of a design language created by Hartmut Esslinger. The Apple // was beige, but the Apple //c was a color called "fog" which also marked the debut of the Snow White design language. The Mac was only ever Pantone 453 and Platinum. It was never "fog". The Mac switched to the Snow White design language with the SE.
Here's some links to other discussions:
https://68kmla.org/forums/index.php?/topic/4024-mac-128k-color/#p90321
https://68kmla.org/forums/index.php?/topic/4073-apple-ii-color/
unity
Doh! You are right, fog. My bad! (FYI, the SE and II came out on the same day and both use snow white for design)
Scott Baret
If you know your compact CRT brands and have a particularly sharp eye, you'll notice the blue color of the CRT if you place a Samsung and a Clinton next to each other. The Samsungs are slightly bluer.
