you could use the monitor 100 on the //e and gs. You have to open it up and change a jumper from 16 bit ot 8 bit video.
inside the Apple color monitor 100 on the main pc bard, almost directly under the neck of
the crt, there is a slide switch labeled "16color/8color. To make the monitor work with the
11gs, set the swith to 8color position, and use the cable provided with the monitor
(svs part# 590-0194A) to connect it to the llgs. This configuration makes all colors
available.
