am trying to repair a Classic II
- replaced the capacitors on the mainboard and the analog board
- removed U14 , cleaned underneath and replaced
- removed egret , cleaned underneath and replaced
- reflowed some connections
problem is when I turn on the Classic II, the attached screen appears, after turning it off and on a few times the classic II will start normally.
mainboard with another analog board same problem, analog board with other mainboard works fine.
So problem must be on the mainboard.
Any suggestions will be appreciated.
