Classic II, no boot
Hi all, been reading through here for a few hours but I can't find any mention of the problem I have.
I got a Classic II from a mate to fix and got it set up and it brought back so many memories I went out and got my own Classic II.
But this Classic II got yesterday just doesn't want to boot, the CRT is lighting up and it's playing the "ding" at power on but then some strange music comes in that's baffling me as it doesn't happen on the other Classic. There is nothing displayed on the CRT at all no matter how long I leave it on for. One thing I noticed (please excuse the "noobish" description here, I was too young at the time of this hardware to know everything) is on the motherboard there are four samsung socketed chips however on this mac it seems one of them has been replaced with a sharp chip, or maybe this is normal.
Here's the mac booting: http://www.youtube.com/watch?v=8SUfdUbsnvM
Any thoughts appreciated,
-maiden
Patrickool93
Those are the chimes of death. It signals a hardware problem. You'll want to reseat the RAM and unplug the SCSI cable to the Hard Drive. then power it up, and see if it will start up to a flashing floppy disk.
I done that yesterday to get it this far.
I just gave it the good ol' whack on the side and it booted [:O] ]'> .
Afraid to turn it off now in fear of not turning back on.
Anything else I could try to ensure turning back on?
phreakout
Reseat the RAM, unplug disconnect all external devices, floppy drives, SCSI, etc., except keyboard and mouse, disconnect internal SCSI hard drive cable from logic board, check Lithium CMOS battery (purple and green) for correct voltage, zap the P-RAM (Parameter RAM), if there is a ROM SIMM, then reseat that. If all else fails, remove RAM, disconnect internal SCSI cable, remove Lithium battery and turn on. Power on for 5 seconds then turn off. Reconnect everything and see if it turns on and boots. If not, I would suspect a bad capacitor problem or a bad filter on the logic board.
Let us know what you do.
73s 8)
Ok so turned her off there before I went out and about. After turning it back on and no joy, so left it on and came back 20 mins later and it was on. Sounds like caps to me, anyone else think that it supports it?
MultiFinder
If some percussive maintenance got it working again, I'm gonna go out on a limb and say that something's loose. Go through the box and check every bloody little thing, even if it doesn't look like it even has a connector. Reseat everything in sight. If that doesn't fix it, THEN go for complicated things like caps and such.
Also, when you take out the RAM, make sure your hands are clean and wipe off the contacts with your fingers. That might just be the issue.
