rezwits
I recently compared the speeds of two different CF Adapters
PCI ATA 133
http://www.ebay.com/...eUAAOSwcwhVQZ6Z
IDE Adapter (1)
http://www.ebay.com/...7gAAOSwgQ9VrbWO
SanDisk 64GB
http://www.bestbuy.c...2&skuId=2037002
PowerCable(s)
http://www.ebay.com/...I4AAOSw14xWL8Gk
the this other adapter which stated UDMA:
Addonics, IDE Adapter (2)
http://www.addonics....s/adebidecf.php
Long story short, even tho the Addonics states UDMA, I was only able to get less than DMA-33.
The cheaper one from above, came in at around 3MB/s faster in 3 tests I performed.
13MB/s vs 10MB/s
So go with the cheap China ones if you have a Beige G3 even with an ATA card, only for convenience,
I really pulled my hair out hoping to get at least around 40MB/s,
and the SanDIsk Card is rated at 800x 120MB/s.
Addonics has a non-female version which I would have to mount in the hard drive bay, that they say up to 133/MBs but I just don't think they can deliver in this machine:
http://www.addonics.com/products/aeudmacf.php
Says up to UDMA-6 (133MB/s), but I can't find any that would fit into a PCI ATA card conveniently, without ribbons
So don't waste your time, unless somebody wants to try the UDMA-6 one listed above.
Hope this helps a little...
Laters...
PCI ATA 133
IDE Adapter (1)
SanDisk 64GB
PowerCable(s)
13MB/s vs 10MB/s
Laters...
