Caps! -- LC 575
uniserver
Just re-capped with Tants installed.
This one after the re-cap, in testing, was doing something VERY strange with with floppy drive in my CC. Clunk Clunk Clunk.
I pulled it back out and did some inspection, noticed some oddness with some traces going under one of the tant caps.
ended up lifting one pad, fixed it with a little bit of wire wrap,
also this one had lots of corrosion. I used the dremel with the wire wheel to get all the corrosion. also looks like this one was ran in a dish washer.
You can really tell. There was white caky residue in between many of the ic pads.
uniserver
By the way, it does work just like it should now.
I can't say what exactly I did to fix it, however my guess would be the corrosion in between the IC pads, there is not a chip that says SWIM, it was probably integrated into one of the VLSI chips.
