uniserver
This one is pretty easy.
Change all the Brown caps in the area right near the transformer,
You will find as you remove them, these are the ones that are responsible for the strong FISHY smell.
I don't have locations, however the caps are clearly labeled.
one - 1000uf 10v
one - 1000uf 16v
one - 1000uf 35v
two - 2200uf 10v
one - 2200uf 35v - this one was by far the worst out of all of them.
You can get all these at mouser.com - I suggest spending a few cents more per cap and getting panasonic 105c, All though, I am sure an 85c cap in the cheapest brand would work just as good. Either way all normally stocked caps.
one - 1000uf 10v
one - 1000uf 16v
one - 1000uf 35v
two - 2200uf 10v
