Chopsticks
Im wondering if anyone knows how difficult it would be to modify system software installers to change what is installed and to add things
for example there are some system file modifications that people like to use and also essential things like the 2020 control panel for dealing with modern date times.
there are some patches allowing HFS+ support on mac os 7.5.5 and 7.6.1
there are patches to the boot resource need to use SE/30 machines with 32bit ROMs some system versions
and likely many other things that are aren't listed above
so was wondering first if its possible and secondly does anyone know what would be involved in modifying systems 7-8.1 to either adding this things or better yet adding a installer Option for things like this?
