Bus Mouse II Disassembly
LC_575
How does one take apart a Bus Mouse II? Mine is making a weird noise when clicking on the right side, as if the plastic were failing. I'd like to inspect it.
Dennis Nedry
The screws are accessible beneath a sticker on the bottom of the mouse. They are never beneath the pads that contact your desk or mouse pad. If you remove those, they will never stick back on adequately.
The sticker ALSO never sticks back on well. You can either peel off the sticker completely or stab through it with a sharp phillips screwdriver.
LC_575
Well, whatever was wrong with it is fine now. Even then I wouldn't want to disgrace the product label.
