British keyboard + System 3.2 issue
james_w
Hello chaps,
I've recently added an HD20 to my 512k and have installed 3.2 in order to do AppleTalk networking etc.
The only issue is that System 3.2 doesn't appear to be compatible with my British keyboards - can anyone point me in the direction of either a British install of 3.2 or at least some kind of keyboard layout files I can add to the US system I've got installed?
Googling and searching the usual well-known places has turned up nothing.
tanuki65
Try asking Max1zzz; he's in the UK and helped me get a British English Mac OS 7.6.1. Include me in the PM as well.
james_w
@tanuki65 thanks - will do
Got the version slightly wrong - 3.3 - I think it gets upgraded from 3.2 -> 3.3 by the network software installer. Finder 5.5. If that helps at all.
mactjaap
Sorry to revive this post...but how to use Localizer if you only have a hard disk with System 6.0.8. It ask to insert a disk you want to localize. But.....it will try to eject the disk and that doesn't work. There must be a way to do this on a hard disk only system?
BadGoldEagle
Odd... I have never used localiser before, but it shouldn't do that.
Have you tried another disk image? There's one on the mac gui from 1992. Maybe it'll work better with 6.0.8? The one James used worked fine for system 3.2... no idea if it works on system 6.
mactjaap
Thanks for the link! This version of a localizer is a Control Panel. Works perfect on System 6 and also on my System 7.6 ( although I don't need it there).
Downloaded as a CPT file, which you can unshrink with Stuffit expander.
