Booting and gray screen...
jimjamyahauk
A couple of things I'll try tonight are the tips in this forum about seating the device, as one of the problems with the Digibarn chips is getting the Device ID recognised:
http://www.mcumall.com/forum/topic.asp?TOPIC_ID=1568&SearchTerms=am29f040
The forum post also confirms that the PLCC32-DIP32 is the correct adapter to use (http://www.mcumall.com/comersus/store/comersus_viewItem.asp?idProduct=3104)
I've checked the the software has the correct device id for the chip, which it does:
http://www.ourchip.com/NZILIAO/chips/memory/AM29F040.pdf states that the manufacturer id is 01 and the device id is A4.
The software has this entry for the chip (applies to 29F040 and 29F040B):
Name="AM29F040B",ID="01A4",Class="29F040B",Category="FLASH",MFG="AMD";
Dennis Nedry
Your setup is a good one; I don't think you have to worry about damaging the chips.
Interesting that your original flash ROMs dumped properly but not the Digibarn ones.
I would try to reduce the speed of the dumping process if you can. I would think that's the most likely to make it work. RAM/ROM can be very picky about timing.
Next, if that doesn't work, I would dig out a 32-pin DIP socket with long leads, similar to this:
You can see the pinout here of the ROM with and without your PLCC <-> DIP adapter:
Insert your flash ROM into the adapter, and now the pinout of the adapter is the same as the left, DIP pinout in the image above. Insert the adapter (containing the ROM) into the DIP socket (top image), and simply bend DQ3 out of the way, and then DQ4 into its place.
If this works, the dump will still be screwed up, but it should now contain the missing bit, making it possible to mathematically derive a good dump from it, combined with your previous dumps.
There are some other experienced people here that could verify that swapping data bits like this is not a dangerous thing to do if you feel uneasy about it.
Dennis Nedry
Right, I think I've got a proper dump this time - selected the slowest speed and it worked fine for the even ROM chip and was a bit more flakey on the odd ROM chip - but eventually got a successful ID check, read and verify.
The latest dump is here: http://www.jkalittle.co.uk/jkalittle.co.uk/OF_2_3_dump3.zip
The even dump now starts with 0x 4800 0008
James.
Dump 3 was successful!
Original, de-interleaved into one file:
http://www.d.umn.edu/~bold0070/temporary/original_interleaved.bin.zip
Dump 3, de-interleaved into one file:
http://www.d.umn.edu/~bold0070/temporary/dump3_interleaved.bin.zip
Dump 3 sound 1:
http://www.d.umn.edu/~bold0070/temporary/digibarn1.aif
Dump 3 sound 2 (PEX sound):
http://www.d.umn.edu/~bold0070/temporary/digibarn2.aif
Original sounds (same as before):
http://www.d.umn.edu/~bold0070/temporary/OF_2.0a9.aif
The PEX sound is cut short, but it also has a subtle fade-out at the end which clearly indicates to me that this was on purpose. I believe these dumps are all good now.
Dennis Nedry
Cool!
So... Any way to combinr the SIMM dump and the Flash dump so I can run it in sheepshaver?
I don't know. Maybe but it's probably not worth the trouble. I don't see how it would work any different than, say, a 9600 ROM. You would probably have to tweak SheepShaver. Notice that SS doesn't have a startup sound when you first launch it. So it isn't probably using the whole ROM anyway.
jimjamyahauk
Duplicating the Flash chips should be easy now, but do you have any plans to duplicate the ROM SIMM?
Yes - I bought a tape of 10 same model AMD FLash chips to ue to duplicate the flash dumps on - will be doing this and testing them soon.
I will try to duplicate the rom simm - or design one which has removal flash chips for the rom simm socket.
Somone on the applefritter forums already has pcb layout schematics and pinouts for rom chips that he helped design/manufacture for powersurge/beige g3s and clones.
If you know anyone that knows anyhting about this that would be good to know.
System7
Banned
The guy saying " I know that I rescued this company" is Gil Amelio. That voice matches up with his in an apple press release.
jimjamyahauk
Fascinating - my other half doesn't like this startup tone - says it creeps her out!
Do you happen to have a link to an audio press release of Gil Amelio - I've tried Google but to no avail.
Dennis Nedry
If you have your own custom sound that is the same length of time, we could insert that into the flash dumps and reburn them. Wouldn't THAT be cool - a Mac that you could customize the startup sound.
I don't know of another Mac with such easily-modified ROM.
Temetka
James.
Dump 3 sound 1:
For some reason I can't get these files to play under OS X.5.6.
What gives? I really want to hear them.
Thanks.
Temetka
The movie file could not be opened.
The end of the file was reached.
I re-downloaded them and had the same problem.
They originally d/l with .AIF, i changed them to .AIFF and still no go with quicktime.
10.5.6, everything up to date.
EDIT:
Massive FAIL!
Not really.
The file digibarn.aif is 263 bytes.
The others files are fine.
Dennis Nedry
Digibarn1.aif is 256k
Digibarn2.aif is 256k
OF_2.0a9.aif is 512k
These are the only 3 files. I just downloaded each of them and they play fine for me. There was another audio file from a bad dump earlier in this thread which was the same as Digibarn2.aif, but it sounded bad. I may have deleted this file from my web space, you may actually be downloading a small 404 HTML file which QuickTime Player can't play.
Temetka
Weirdness than.
I must have done something to d/l a 263 byte file, what it is I don't know.
I have all 3 working files now.
Must say that new startup sound is awesome.
Wonder if I could hard code it into my PBG4.
That'd piss Steve off good.
Dennis Nedry
Weirdness than.
That's probably because of the minimum block size on your hard drive. Often times files will show up a few kilobytes bigger than they actually are.
If you can edit the ROM you can.
Beware that the normal startup sound is 22kHz stereo and I think this PEX one is 44kHz stereo so you may either have to downsample the audio to 22kHz or hack the actual playback sample rate somehow.
iMac600
I'm going to dig up this thread. I can't honestly believe that I missed it during the original post cycle, being such an avid Macintosh PowerExpress fan myself. I still have copies of CaptainZ's MP3 audio dumps from years ago:
Macintosh PowerExpress (9700) Boot Chime (60kb)
Macintosh PowerExpress "Manhattan" Death Chime "Kill Me!" (116kb)
Macintosh PowerExpress "Manhattan" Boot Chime "Gil Amelio" (128kb)
Unfortunately that's all I can offer since the rest of my knowledge is all up there in the ol' brain. Interesting thread though, and congratulations on getting the mythical beast to boot. :D
trag
Well, I wish I hadn't missed this thread before.
Now that James has found sockets for the PSOP-44 chips, it would actually be pretty easy to modify the ROMs on the entire x500 and x200 family--oh, and probably the x100 family as well.
Remove the existing ROMs, install the sockets, then program/reprogram PSOP-44 8 Mbit Flash chips with ROM code.
I've done some work where I've desoldered and replaced the ROM chips with Flash chips with the Kansas ROM. My Umax S900 which is my main machine at home has Kansas ROMs installed.
The original soldering job might be a little challenging (routine for me), but after that you just need a programmer which will handle the 44 pin PSOP flash.
If you have a Power Computing ROM SIMM it can be a little more interesting. Replace the ROM chips with PSOP-44 sockets again. Find the 1Kohm resistor which ties pin 116 of the ROM module to GND. Remove the resistor and connect the pad which connects to pin 116 to 5V.
In the x500 (and 7200) family of Macintoshes, pin 116 of the ROM DIMM socket is connected to the CE_ (chip enable) pins of the logic board ROM chips. These pins are active low and they are weakly (~4Kohms) tied to ground. If you tie pin 116 of a ROM module to 5V and then plug in the ROM module, it will tie all the CE_ pins to 5V and disable the logic board ROM chips, allowing the chips on the ROM module to take over.
So, once you have such a module, you can plug it into an x500/x600/x200 family machine and reprogram the socketed chips as desired.
Here is the pinout for the ROM module. The PS stands for Power Surge which is the x500/x600 family. The Beige, PowerSurge and NuBus Power Macs all use the same pinout. The Beige uses the 3.3V pins for power supply, while the others use the 5V pins.
http://www.io.com/~trag/Apple_pinouts/Firmware_Module_Pinout.txt
I've had the hardware ability to modify the ROMs for about seven years, but I'm not much of a programmer/hacker.
