Specifically examine the pictures for a Master/Slave jumper. You will only find one in the 3rd photo. Once you've found that though, you can then see parts of that jumper in that position in two of the other photos, though you cannot read the labels in those other photos. However, on the first phot, that jumper should be clearly visible at the righthand end of the adapter, under the power connector. And it is not there.
