drybones99
I have a Beige Macintosh Plus, likely converted from a 128k/512k, and it has been working fine for the past several months. Just today, however, I was using MacTerminal, trying to get my Apple Personal Modem to work with it and connect to a BBS, when all of the sudden, everything on the screen seemed to collapse into itself, and I heard a high pitched static noise, accompanied by the smell of electronic smoke. I turned it off in a panic. Turning it back on, The high pitch noise returned, and the screen lit up, but it was distorted. I could not see anything, but some curved patterns. As I continued to troubleshoot, the screen would light up more and more dimly, until it wouldn't light up at all! Now, when I turn it on, I don't even hear the startup chime, just the disk drive moving one step. If I leave it on for too long, the analog board starts to smoke, I believe coming from the flyback transformer. I have tried adjusting all of the pots on the side, to no avail. Even adjusting the screen cutoff doesn't fix anything. I believe that the problem lies in the flyback transformer, and the way it provides voltage to the screen. Does anybody here know if the problem is in the flyback transformer, or if it has to do with something else entirely. If the flyback transformer is the problem, what can I do to replace it? Where could I get a new flyback transformer?
