Beefier Power Supply for SE/30
JDW
While shedding some tears over the loss of such a tremendous amount of data on this site, I have decided to do all I can do to restore what's left of it via Google's cache. One of my most extensive threads was concerning the use of a better PSU or secondary PSU to offset the load on the stock SE/30 power supply. This becomes important when adding fast 7200rpm or 10krpm internal hard drives and multiple PDS cards. I will resurrect one of my more detailed posts here...
Here are some photos I shot well over a year ago of my SE/30 setup at that time (click "All Sizes" in Flickr to see larger versions):
Machine Back View
Mounting Bracket
Mount Bolted to SE/30 Frame
Bracket
Tapping AC
Panaflo Fan#1
Panaflo Fan#2
Panaflo Fan#3
Secondary PSU Mounted on Wood
CRT Flyback Cup Area
Back of Yoke Area
You'll find detailed text descriptions for each photo on Flickr. The photos show the insides of my SE/30, the JAMECO PSU driving my hard disk and the Panaflo fan cooling the secondary PSU and the Turbo 040. I put my camera on a tri-pod and did not use a flash so more detail can be seen.
I suspended the secondary PSU between the PDS cards and the yoke with 3 stainless steel L-brackets found at any hardware store. The only modification to my SE/30 case was a couple of drill holes to secure the lower L-bracket. The wood block simply made it easy to mount the brackets and PSU and eliminated worries of shorts. You can see in one of the photos were I tapped the inside of my SONY PSU to feed AC voltage to my secondary PSU.
I also removed the BNC connector on my MacCon card, leaving a gaping hole. Air can flow into the machine through this hole, as well as from the bottom of the case. The Panaflo fan throws air from top down, and the stock fan circulates everything out.
It took a little time, but I don't consider this a serious hack. I tried to make it look nice by covering some of the wiring with corrugate tubing. It took longer to pull the SONY, PSU, open it, solder the AC wires, and close it up than it took to construct the L-bracket mount for the secondary PSU.
JDW
Also in the original thread, we had discussed some voltage measurements taken at the external floppy drive connector on the SE/30. A member by the name of "tt" submitted the following...
SE/30 configuration: Daystar Turbo 040 @ 40Mhz, Asante MacCon, Daystar Adapter, 8 GB Baracuda HD, Sony stock unadjusted PSU, IIfx ROM, cleaned but not re-capped logic board, keyboard, mouse
Voltages:
Idle: 4.78V
HD floppy disk access: 4.78-4.74v
During warm boot from HD: 4.78-4.74v
Idle with HD spun-down: 4.80-4.79v
I posted my voltage values as follows...
SE/30 Cold Boot, Welcome to Macintosh screen, VOLTAGE READINGS:
1) Everything Installed: 4.83v
2) Everything but internal HD connected: 4.83v
3) Keyboard Removed: 4.84v
4) Keyboard & Internal Floppy Removed: 4.85v
5) Only MacCon Removed: 4.91v (keyboard and floppy still connected)
6) Keyboard connected with MacCon/TS Adapter/Daystar Removed = 5.09v
Based on the above, you can see the following is true:
1) IIgs Keyboard Voltage Drop when connected: 10mV
2) Internal SuperDrive Floppy Voltage Drop: 10mV
3) MacCon Voltage Drop: 80mV
4) Daystar Turbo 040 40MHz + TS Adapter Voltage Drop: 200mV
Another Voltage Observation:
Even with my SONY PSU cranked up to maximum voltage (via the variable resistor inside the PSU), I still only get 5.1v max output. I know my HD isn't dragging this voltage down because the HD is powered by another supply. And I tested to confirm that my secondary HD PSU in no way affects the voltage readings measured above. So then question then is, is 5.1v the maximum output of the SONY PSU? Obviously, I will need some of you to test this in order to compare.
And finally...
I conducted more tests in an effort to resolve my internal floppy drive issue. Sadly, I was not able to resolve it to my liking. As reported before, I cannot read/write 1.4MB HD floppies when a IIsi or IIfx ROM is installed along with the Daystar card; but I can read/write 800k & 400k disks just fine in the same configuration. With the Daystar installed and the stock SE/30 ROM installed, the HD floppies work fine. Again, I have reported all this before. Today, I removed the Daystar and tested with a IIsi ROM installed. HD floppies work fine!
What does this test prove? Well, we cannot simply say it is the Daystar card causing my floppy drive to flake out because HD floppies work fine with the Daystar card installed IF the stock SE/30 ROM is also installed. And we cannot simply say it is the result of using a non-stock ROM because I verified a IIsi ROM works IF the Daystar card is removed! So it appears to be a combination of things, BUT WHY?!?!
Another member by the name of "Tyler" posted that his voltages covered at close to 4.60v. I then replied to Tyler as follows...
Jag (from Jag's House) claims the "spec" says the SE/30 motherboard will work without crashes within plus/minus 0.5v from the nominal 5.0v level. I then asked Jag where he got the information and all he could say was "from memory." Not liking that answer, I posted here to see if others could post their voltages to compare. Now that two of us are showing fairly low voltages (and yet the computer works), it does give some credence to Jag's claim.
But let's assume Jag is correct. This means that anything below 4.50v will assuredly result in a system crash or other anomaly. In this case, it is very possible that some operation could result in a low voltage spike, just below 4.5v for a few milliseconds, resulting in a crash. This is especially true, I would think, on your machine, Tyler. Since you are showing only 4.6v.
On my machine, I measure 4.8v or so for a while, but as the machine is left on the PSU warms the the voltage drops. After about two hours, I starting measuring voltages as low as 4.70v at the external floppy connector. So you may wish to conduct the same experiment. I assume your voltage check was down at cold boot. That's good, but now leave the machine on and the DMM connected. Run Norton or some speed check utility and check the voltage level at regular intervals. If your machine is like mine, as the PSU warms the voltage will drop. I would be curious to hear how low your voltage can get without a crash.
By the way, my Sony PSU in the SE/30 had its voltage adjusted up to max, and yet I was still measuring those rather low voltages.
MacSE/30
Why sticking in a second psu? Why you have not replaced the original psu with a more powerful one?
Just wondering?
JDW
The SE and SE/30 have a separate power supply box. In other words, the SE-series is unlike the Mac 128k to Mac Plus -- early machines which had the power supply components built into the analog board on the side of the machine. Hence, you can change out the power supply (PSU) in SE-series machines without changing out the analog board.
So why did I not do just change out the PSU? The reason is because you have to not only find a PSU that is small enough, but also one that would supply more power than the original while at the same time remain cool, and find one that has an ISOLATED set of two +12v outputs. The need for two isolated 12v lines is because you need one 12v line for the drive and the other for SWEEP (CRT). If you use a PSU with only one 12v (as most are), then noise could possible creep onto the CRT display. I don't want the potential for more noise in my machine, so I have been searching for a compact PSU with two separate +12 outputs (along with 5v and -12v outputs) that would be ideal for the SE/30. I have yet to find one like this.
It is therefore easier to add a second PSU as I did to offload the biggest load on the machine -- a big hard disk. Of course, if you buy an external HD case, you could accomplish the same -- albeit with a slightly bigger footprint overall for the system (relative to everything being in the same box).
tt
I remember this lost thread originally before the forum crash and would like to revive it to see if anyone has advice on PSU alternative. If I want to replace the inner stock PSU PCB (and keep the original sheetmetal enclosure) with another higher wattage PSU, does anyone have a recommendation or pointers to look out for spec-wise? I am looking at the Artmix "stregthened" PSU as a guide on what to look for in a replacement. He has one that is 145W+20W and has two separate 12V rails (an extra for CRT sweep to minimize noise), while implying the stock PSU has one 12V rail. Finding a quad output, 5V, 12V, 12V, -12V PSU seems to be difficult (as JDW mentioned earlier) for the physical size constraint and also tend to be expensive. What would be really necessary to get a better PSU installed for configurations that have multiple PDS cards installed? Any thermal considerations for going bigger?
Code:
Artmix PSU Specs
+5V - 14.5A
+12V - 3.75A
+12V - 1.5A (sweep)
-12V - 0.5A
Stock PSU Specs
+5v = 6.0A
+12Vsweep = 1.25A
+12Vdisk = 2.1A
-12V = 0.5A
JDW
I always keep a JAMECO catalog marked up with the latest SE/30 PSU replacements (yes, I am THAT nerdy):
EOS POWER Open Frame PSU — 80W (only one +12v out, no separate +12v out for SWEEP)
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?freeText=2081721&langId=-1&storeId=10001&productId=2081721&search_type=jamecoall&catalogId=10001&ddkey=http:StoreCatalogDrillDownView
MEAN WELL Open Frame PSU — 124W (only one +12v out, no separate +12v out for SWEEP)
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?freeText=301487&langId=-1&storeId=10001&productId=301487&search_type=jamecoall&catalogId=10001&ddkey=https:OrderItemAdd
MEAN WELL Enclosed PSU — 132W (only one +12v out, no separate +12v out for SWEEP)
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?freeText=323775&langId=-1&storeId=10001&productId=323775&search_type=jamecoall&catalogId=10001&ddkey=http:StoreCatalogDrillDownView
MEAN WELL Enclosed PSU — 124W (only one +12v out, no separate +12v out for SWEEP, but has +24v out)
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?freeText=323812&langId=-1&storeId=10001&productId=323812&search_type=jamecoall&catalogId=10001&ddkey=http:StoreCatalogDrillDownView
So the question is, does the SWEEP really need a separate (isolated) +12v source. If so, then none of the above replacements will work. I've wondered this for YEARS, so if anyone has the answer, it would really be helpful.
James1095
If finding a power supply with two isolated 12V outputs proves difficult, in many cases it's fairly simple to add an additional output. The transformers in switchmode power supplies tend to have a high volts per turn ratio, so you only need a few turns of wire on the core to get 12V. Assuming there is room on the transformer, just add the necessary number of turns using magnet wire sized for the current needed. Add a fast rectifier and filter duplicating that of the existing 12V output and you should be good to go. In almost all of these, only one output is monitored for regulation, the rest of the voltages follow. There are a number of articles out on the web about modding surplus computer PSUs for other purposes that detail this sort of thing.
JDW
Actually, it would be cheaper and simpler to just add a voltage regulator or DC-DC converter to the last MEAN WELL PSU in my list above, to drop the +24v output down to +12v. Then you'd have two isolated +12v outputs, no transformer required.
But truly, it would be best and cheapest to have everything you need in one box that is warrantied by its manufacturer. Surely there must be a PSU out there like that. I've just not found it in the JAMECO catalog, which is where I bought the PSU you see in this dual-PSU SE/30 rig I built:
http://www.flickr.com/search/?q=se%2F30+psu&w=66071596%40N00&m=tags
techknight
I have a muuuch better idea.
Small Form Factor power supplies.
http://www.ebay.com/sch/i.html?_odkw=micro+HP+power+supply&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313&_nkw=small+form+factor+power+supply&_sacat=0
Look for those, i have a couple of HP pulls at work i can take a look at and figure out its ratings. Plus, this enables the use of soft-start as well, as this was being worked on earlier for the SE/30.
Want smaller?
ITX power supply:
http://www.ebay.com/sch/i.html?_trksid=p5197.m570.l1313&_nkw=ITX+power+supply&_sacat=0&_from=R40
The only pitfall with modern power supplies is the -12v rail. Its rarely used these days, so the current max output has dropped from 0.5 to 0.3a on alot of them. So, Someone needs to take an ammeter and put it on the -12v rail of the SE/30 and find out what the max current draw is on all conditions, including reading/writing floppy and playing sounds.
But out of all of them, the Apevia brand seems to be the best suited. Looks small enough, and has plenty of power capability. Limitation is the -12v rail. So This has to be tested... And with ATX, You get Standby ability with PW-On signals. So someone can tap into the VIA chip to get the shutdown signal, and tap into the ADB plug to get the PW-Key signal, and run them into a PIC or Atmel based board that is powered via the standby 5V.
So, when pressing the power key the PSU will come on. Like an ordinary mac. And with the proper extension from another thread, shutdown command will turn the mac off.
James1095
DC-DC is easy enough. If you already have an isolated 24V output, you can get cheap compact buck regulator modules based on the SimpleSwitcher ICs for a few bucks on ebay and elsewhere good for 1.5-3A. They're easy to use and quite efficient.
tt
Interesting idea. I think the FlexATX or TFX form factors could fit nicely. I would probably want to remove the PCB from the enclosure to transplant it in the old one. Would removing the fan be OK since the load is low for the 250-300W PSU's? And is there an issue of not using the 3.3V rail (or other unused rails) to a minimum level to kick-start the PSU? Any advice on reputable suppliers?
tt
I looked into TFX PSU's and others, but it looks like it is common that the 12V rail, even if the specs say it is two rails, it actually only has one common rail within the PSU. So that brings up the previous question, can we get away with just one rail that is shared with CRT sweep? I am hesitant to experiment with that question since power issues can bring up subtle problems that I don't have the tools to vet and isolate. Also most new units are now 300W and higher, and fan cooled, so does it make sense to run it at ~20% load @ ~80% efficiency with just passive cooling?
JDW
I did a lot of research on various PSU's in the past. Most all of them have a single +12V rail. That's why you're better off just going with one of the power supplies from JAMECO that I suggested, especially since none of them have a loud fan on them like the ATX supplies have.
