On that page they specify that a G4 has to run on a slower bus, not the G3. http://68kmla.org/forums/viewtopic.php?p=34419#34419The Powerlogix 1Ghz G3 ZIF runs at 66Mhz too
http://eshop.macsales.com/item/PowerLogix/PFZGX10001M/
If you are stuck running at 66Mhz on a 1Ghz G3 @ 66Mhz why not buy a 1Ghz G4 upgrade for a PCI Mac for $96 which runs at 50Mhz and has 2MB cache onboard to upgrade a nice 6 slot 9600?
i think its a bit more then just $100$100 to bring my 8500 to 1GHz.
Man, that is so awesome.
ooh, i missed that one. thanks for correcting meDid you even look at the link I posted above, the G4 is on a card that plugs into the PCI powermacs CPU slot.
http://www.outofspec.com/frankenmac/wire.shtmlThe B&W PSU connector is the same as the Yikes/Sawtooth.The early G4s have different power supplies I think, you are better off getting a complete unit.
