AsanteFast driver not working?
Gil
I restored my Performa back to its original factory settings, but when i install the driver for my AsanteFast PCI Ethernet adapter, i open the control panel and it says it can't open because there is not enough memory, but there is more than enough memory (72 MB physical RAM, 75 MB Virtual memory).
Also, i remember there being a control panel (I'm running OS 7.5.3 Revision 2.2) that asked if I would like to use MacTCP or Open Transport, but i cant find it?
Unknown_K
Try reinstalling the Asante drivers manually including the control panel. Open transport came out of the 7.5.2 OEM cd for the first PCI powermacs, but I am not sure what standard OS release it was included in. Maybe you need 7.5.5, I know 7.6.1 has it.
equill
Even if you are using the Asanté EtherTalk Installer diskette v5.6.1 (the latest), it is wise, and Asanté themselves made the point, to install their software first, and then OT 1.1.1 and 1.1.2. This makes sure that no older software can replace the necessary files installed with OT.
If you go here you will see that Asanté distinguishes between its AsantéFAST cards according to controller make. They presumably know their own products, and it is worth your while to make sure that the software for your card is in accord with their protocol, too.
I use more than 20 Asanté cards (and a few from Apple) throughout my LAN, and they give no trouble.
de
