equant
I can connect to my iBook's (9.1) drive from my SE (6.0.5) using Appleshare and Ethertalk. On the SE, I can copy files from the iBook, and run apps from the iBook with no issues.
The problem is when I try to copy files from the SE to the iBook. No matter what file, and what size, I get the same error...
Does anyone know what is causing this issue?
Is this an issue known to ethertalk? I'm running Phase 2, with an Asante ethernet card. Or... is the SE asking how much space is available on the iBook and it's not able to comprehend 2.34 GB of free space?
I've tried large files, and small files (13 bytes), I always get the same number of bytes in the error message. The SE HD is not full either; not that it *should* matter.
Thanks,
Nathan
Code:
There isn't enough room on the disk to duplicate or copy the selected items (additional 1,773,128,704 bytes needed).
Thanks,
Nathan
