jmacz
I had System 6.0.8 running on a Macintosh SE which was installed without AppleTalk/AppleShare support. Games worked great on it. I recently re-installed 6.0.8 with AppleTalk/AppleShare support in order to share files between the SE and another Mac running 7.5.5. That worked great. But tonight I tried loading up some games and found that a couple of them were erroring out with a graceful in game error message stating there was an issue with the memory layout (high memory) and that I should boot the game from floppy instead. First time I’m seeing these errors. The games in question were Dark Castle and Arkanoid. Other games seem fine.
After removing the AppleShare extension from the System Folder, I can get both of these games to work. But if AppleShare is loaded, then both of these games error out with the complaint about memory layout. Is this a known issue? I’ve tried newer versions of the games (for example Dark Castle 1.0, 1.1, and 1.2) and all have the same issue.
