In a current Conquests thread on a PB165 there has been discussion of correct ratings for power supplies that should be connected to various PB models. The official Apple support document seems to suggests you should not connect a PSU that exceeds the recommended level of "watts".
I don't get this. Normally PSUs are rated in voltage and amps, and these determine how much current the PSU can push through a given resistance. Are Apple's machines and/or PSUs designed without any over-current protection, current-limiting or fuses? To my understanding, any PSU at the correct voltage will only deliver the watts that the circuit requires, if it has the amps to do so. You'll only draw excess watts if you have a short circuit of some kind.
I've never heard of a PC, for example, that would be damaged by a PSU capable of delivering more watts than the machine actually needs. In fact, most PSUs are at way below capacity almost all the time.
Please enlighten me if I have missed something.
Rick
Rick
