What RAM setup did you have?Well I got back to it today. I now have the other board and i Re-capped it today. It is a much cleaner board but there were a few visible broken traces I had to fix. Anyway, after cleaning and re-capping, the board makes the sad mac sound on power up. But at least this board is booting and I can see square wavs on the ROMS.
I tried connecting a video card up to a monitor but there nothing.
When I probe the pins on the NUBUS I see nothing. When I probe the lower pins of UD and UCI have signals but none on the upper pins of the chips.
Another issue I see is when i connect the actual IICX power supply, after a short delay the power supply just turns itself on and the green LED on the board lights but the rest of the board is not powering up and the soft power button does nothing. So there is also something wrong with the power circuit. Not sure if they are related though...
So, since this board is in "better" shape I guess I will focus on repairing it first now.
Anyone have any ideas on what chips to look at?
Unfortunately that’s all I’ve got.I wouldn't use that as a test video card. Got anything lousier?
Standby for more ideas when I get to my computer
Are they all the same SIMMs?I loaded all of the banks of ram but I’m not sure what the minimal requirement is.
Thats normal remove the ones you added. Google pictures of the board.I just noticed D1 and D2 are strangely missing from the board!
Video out is the important thing. If you get video working you can see an error code.Anyway main issue is the sad Mac chime when powering up off the bench atx supply.
Yes all the same ram chips.Are they all the same SIMMs?
Then Nubus firstBut no Nubus = no video.
The original bad board we were working on has them. So I swapped and neither board behaved differently.Basic steps of troubleshooting are always voltages, clocks, reset.
However, if you look at the schematics, D1 and D2 both directly affect the power-on circuitry. They weren't there, why add them?
The board revs are identical.Ok, but boards undergo revisions. You shouldn't assume things about component placement.
The solder on the pads looked factory, there is likely two variants.Since my original bad board that I’ve owned since new has then and the new board I got that is the exact same version number does not have them I thought someone might have removed them.
