OleLila
This is my first post on the forum and despite searching here and elsewhere, I have not been able to locate anyone with this issue. I like to think it is because I have a rare machine here, but the answer maybe obvious. Regardless of outcome, I just do not like the thought of an unusual find leaking caps and battery to the point of no repair.
I had obtained a Macintosh SE with a Radius full page display and Radius accelerator (version 1.8) about 9 months ago. I thought when it arrived I would take the logic board out, remove the battery and maybe recap it. On opening the case I found I can remove the video card portion of the radius expansion, but there is also an accelerator board that lies on top of and parallel to the original main board. I can't imagine how they put this together without either major flexing of the accelerator board or taking the frame apart then spot welding it back together. The slot on the accelerator card for the video card protrudes through the metal frame, it does not allow the main board to slide enough to clear the tabs for removal. Below are some pictures, I think the second one shows the primary issue, if you can imagine trying to take out the SE's logic board and having that slot butt against the frame. I've had this machine apart several times and if there is a simple answer, I'm ready to hear it.
Thank you.
Thank you.
