A/UX Install Issue - SCSI-IDE Adaptor
istar1018
Hey all -
Anyone have any luck installing A/UX 3.0.1 on anything with a SCSI-IDE adaptor. I've got an ACARD SCSI-IDE adaptor on my Q950's internal SCSI bus, and I've tried to attach it to various things - an old Quantum fireball, a CF adaptor, a 6.4 gb WD drive. Regardless of what is attached, the A/UX install boot process hangs when the Welcome to the Apple Workgroup Server 95 progress bar is completed (when the text changes to say Please wait. This will take a while.).
This same Q950 boots into 7.1, 7.5.5 and 8.1 just fine with the ACARD adaptor, so I think it works... and when I remove the adaptor, A/UX setup boots just fine (albeit with complaints about the lack of SCSI drives). I'm using original media, so it shouldn't be a disc issue.
Anyone gotten this to work or have suggestions about how to tweak the install process?
Thanks!
istar1018
It definitely is not lying, as I let it sit overnight, and nada. No progress.
The Quantum and the CF card are smaller than 2 gigs, the WD is bigger. The WD is partitioned into a few 1 gig partitions and then some free unpartitioned space. I've tried the Quantum pre-partitioned and with all partitions deleted, and same for the CF card.
Termination should be okay, since everything is rock solid under normal Mac OS.
benjgvps
Could it be an Apple ROM issue? Don't the hard drives need to be formatted with the Apple disk tools or a patched version to allow the drives to function with the computer?
porter
A/UX requires different drivers to those used by Mac OS. NuBus cards may contain drivers for Mac OS, but not A/UX (as far as I know).
Operating systems often have a hard job using a volume as it's root drive for which it does not have a driver in the kernel.
istar1018
Well, so a bit of an update. Yes, all of the drives are formatted with Apple tools - either hacked HD SC setup, A/UX HD SC setup, or Drive Setup in Panther.
No dice.
When I remove the drives but leave the acard adaptor connected to the scsi bus, A/UX setup boots but then complains about having no scsi disks... hmm.
