Dennis Nedry
I believe that the partition on my A/UX system is damaged because every time I boot it up, it comes up with all sorts of disk errors. It asks me to fix them, which I say enter "Y" a million times (lots of errors), and eventually it fixes it and reboots. It then boots to a terminal instead of the Finder. If I shut down and restart, all the errors come back.
I have a good install of A/UX 3.0.1 on an external HD, and when I boot form that on the Mac, the Mac partition of the internal HD mounts, but not the A/UX partition.
I can only assume the A/UX partition is damaged. If I can repair the partition, I think it would be fun messing around and copying files form the external HD into the internal to figure out specifically is wrong, why it won't boot to the Finder. Just for fun. I could just wipe the drive and reinstall everything, fixing all these problems easily, but where's the fun in that if I don't know what actually went wrong?
So I found a 68k version of Norton Utilities (v3.2), and I ran Disk Doctor on the internal HD. But Norton can't do anything to an A/UX partition. What can I do to fix the A/UX partition without reformatting? I am able to boot A/UX from the external HD and run A/UX stuff with the internal, damaged HD present if that helps at all.
