Since I decided this week to set up an Appletalk network in my studio/bedroom, it occurred to me that I really should set up my 8600 a bit better. It is a decent transitional box, since it has both RS422 serial and 10baseT, so theory has it I could connect any of my other macs on either side and get things done.
I already threw a Sonnet 500MHz G3 in it years ago, which is great. I still have the original 604e here somewhere, I wish I could remember where as it was surprisingly fast as I recall. I had a Radeon 7000 and a 73GB drive from a Sun server which I thought would go well in there... They do, but it took me much longer to get running than I guessed it would, due to me misplacing many things. I copied my 9.1 system from my slow-ish 4GB drive to the new 10k server drive, and used OS 9 Helper to update it to 9.2.1. I finally got around to it for full Radeon driver support. Funny thing is that the new video card makes it take a lot longer to start the boot process, but once the extensions start loading it is much faster than it was before. The faster disk access and video RAM make quite a difference. Also I am happy to be rid of that DB15 adaptor, since I haven't owned an Apple CRT since 1999. This 19" Dell has seen better days, it is dark and the focus is starting to go. With the built-in video it was practically unusable, I felt like I was going blind. It is not so bad now. Best thing it could get next would be a 9600 logic board.
Tonight I will try using it for Localtalk with my SE, and try digitizing a VHS tape on it with JES Movie RAID (http://www.xs4all.nl/~jeschot/home.html)
