mactjaap
The eject motor of one of my 800k disk drives is broken. This motor pulls the eject mechanism to the back and the disk will come out. Without the engine the disk is kept in the device and you have to get it out with a paperclip in the small hole in the front.
One of the small plastic gear wheels is broken. I have replaced the total motor of one of my spare drives, but I would like to repair it because it is from a working unit. Did one of the members of the forum this before? Where to buy these kind of small parts? I tried in a shop with model trains, but no luck.
Here are some pictures so you know where I am talking about.
The disk unit with the motor. You have to remove the two screws (green) and you can remove the motor. Don't forget to remove the small connector too.
Here you see two motors. The top one is OK and the bottom one is the one which is broken. I'm missing the most right gear wheel. This one has two wheels. A smaller and a bigger in one wheel. The defect wheel is on the table most right.
Remove these three screws to open the motor.
