68k ROM Replacement, sans Apple code
DLudwig255
Hello all,
Inspired in part by Jon Sharp's Bare-metal Mac project, and pipe-dream of trying to port the classic-MacOS rewrite + emulator, Executor, to 68k Mac emulators, I did a bit of exploratory work on getting C++ code running under an emulated, 68k Mac.  Using a g++ cross compiler (to m68k), along with some extra, non-m68k, helper tools, I was able to get PCE's macplus emulator to boot, sans any Apple-copyrighted code.
The replacement "ROM", if one could call it that, does nothing more than display a 1-bit bitmap on-screen.  It is mostly C++, with a bit of inline assembly mixed in, mainly to help setup a stack pointer, and to help sit in a busy loop, after writing the bitmap to video memory.
I've posted the code online at https://github.com/DavidLudwig/MacRomPicture , under fairly liberal copying terms (CC0; public domain), in case anyone is interested in looking at it, or modifying it.  I've tried commenting the source code up a bit, to explain some of the non-obvious parts.  Suggestions for modifications welcome.  I'll admit, there is a *TON* of stuff regarding Mac 68k internals that I still don't know about!
Here's a screenshot, albeit a bit of a fuzzy one (macOS Preview.app keeps wanting to blend the colors, when sizing it down):
33515412-01677e18-d731-11e7-95be-aea5e60dd69d.png.aafc0d128f982881f1f8e5e4fefe7842.png
A bootable .rom file is also online, at: https://github.com/DavidLudwig/MacRomPicture/releases .  It boots for me within a copy of PCE's macplus emulator, using a 4 MB Mac Plus (the 4MB part is important, with regards to where video memory starts!).  It also boots when PCE is configured to emulate either a Mac Classic, or a Mac SE.
I'm thinking of trying to extend this code a bit, perhaps adding in the ability to output text via serial, for future, printf-style debugging.
Comments, suggestions, questions, or critiques welcome, if anyone has any!  :)
Cheers!
DLudwig255
On 2nd thought, my next task with this might be timing, rather than serial.  I'm reading that serial drivers in earlier model Macs, such as the Mac Plus, need to wait a bit in-between serial IO operations.
It'd also be pretty cool to have an image bounce around the screen.  :)
Suggestions for resources on such definitely welcome.  Otherwise, I'll probably be diving into one or more of the following:
