veachanderthal
First post and first attempt ZuluSCSI device so be gentle with me.
I have a Motorola MVME 133XT 68020 SBC that I'm trying to run with a compact ZuluSCSI card. The system recognizes the SD card as a drive without SCSI errors, but throws a "bus error" if I try to access it. (Launch application or even a DOS command to see a DIR)
System boots fine on original Fujitsu Drive.
I'm guessing I may need something other than system defaults for configuration, but I can't seem to get the ZuluSCSi device to recognize the zuluscsi.ini file I downloaded. I have it on the SD Card named "zuluscsi.ini", but I get a "zuluscsi.ini not found" message in the terminal along with a blurb about using defaults.
I feel like I'm missing something simple. Like maybe I'm not using or naming the file properly.
