Mac128
Yes, that is true for the internal drive if you are trying to use the MFD-51W-03 with the red cable, however, he is talking about an external drive. All external drives are properly configured to avoid this problem. There is no need to cut anything inside an external drive unless you are using it on a computer not compatible with it ... and the 512K is listed as compatible: http://docs.info.apple.com/article.html?artnum=10268
Pina's instructions to cut the ribbon cable (which as far as I know only appears in the Dead Mac Scrolls, page 249) refer specifically to the internal drives ONLY. The problem he's having with the external drive I suspect is ROM related and cannot be changed without altering the circuit board on the drive or re-writing the 64K ROM since this is a pre-system hardware issue that goes away when you load a system disk. Also, the red cable is designed for use with 400K drives or 800K drives that have the socket header disconnected, so all wires are connected. The original 800K drives disabled the speed control pin at the header since it was unnecessary for the them, so it doesn't matter which cable is used. The newer 800K drives did not, probably so that pin could be used for other purposes as you suggest (eg the IIGS). Whatever the reason, the yellow cable was required which disabled the those pins inside the Macintosh. If you used a red cable with the newer drives, the speed control signal is passed through and the drive goes into an endless spinning & eject cycle. Pina's instructions in Dead Mac Scrolls are greatly simplified and designed to solve your problem without explaining it, necessarily. So clipping the red cable wires with the newer drives would solve the problem, particularly since there are some newer drives with the same part number as the old (confusing indeed). But again, totally unnecessary on the external drive. Cutting those wires on the A9M0106 probably will cause it not to work properly on the IIGS, though should not affect the Mac's operation. Most likely the circuit board in the A9M0106 receives the speed signal from a Mac and disables it, whereas on a IIGS, whatever that pin is used for is applied accordingly. Pina's detailing of the problem in Repair and Upgrade (page 193) "for 64K ROM diehards" is merely informational, probably in the event you don't have the proper ribbon cable. It is very easy to confuse what Pina is saying based on his writing style so I'm not surprised JDW mis-understood.
I suspect that the external disk drive is queried by the system for a disk at a regular interval when attached and for whatever reason the 800K drive does not return the proper answer on a 64K ROM Mac. I'll have a look at Inside Macintosh and see if I can confirm that. FYI, the original 800K drive (M0131) also accesses the disk (though it has no LED to flash) until a disk is inserted. However, without the HD20 INIT on a 64K ROM Mac it cannot be used. This is most likely why the older drives cannot be used in the A9M0106 external enclosures, at least with the IIGS. Though if the circuit board does not receive the speed signal from the Mac, it may not know what what kind of computer it is attached to, should that make a difference. Though since JDW cut those lines, obviously it would seem to make no difference on a Mac.
Lastly, the 800K drives are MFD-51W, MFD-51W-10 (HD20 INIT only), MFD-51W-03 (used in the A9M0106) and MFD-51W-23 which I have seen referenced as used in the IWM Mac SEs. Obviously the last incarnation, I would love to get my hands on a MFD-51W-23 to see if they were further upgraded to avoid the problem JDW is having with the disk access. Just to be clear, I have come across drives labeled MFD-51W ONLY which appear to behave identically to the MFD-51W-03 (without the HD20 INIT), yet can use either red or yellow ribbon cable. Perhaps this is the MFD-51W-23 and Sony had dropped the suffixes at some point. Otherwise, it is a the original 800K drive which Apple subsequently crippled to prevent use without the HD20 INIT. Either way, Pina in Dead Mac Scrolls only refers to these drives as MFD-51W which I suspect is a simplification as a result of the unpredictability of part numbers and their corresponding drives. I will at some point try using the this drive in the A9M0106 to see if it operates any differently.
