Anyone know how much power the 5500/6500 logic boards require? And in which voltages?
I found this case:
http://www.antec.com/Believe_it/product.php?id=MjI0MA==
And I'm pretty sure I can wedge the 5500 in there. But it would fit more easily with the power supply out of the case. The ISK 300-65 does exactly that and includes the external supply, but it only delivers 65 watts. The ISK 310-150 certainly has enough power at 150 watts, but the supply is internal and would probably cause fit issues requiring modification to the case.
On the other hand, the 310-150 is just prettier than the 300-65. They need to sell a 310-65.
I found this case:
