BadGoldEagle
Hi
I'm currently trying to troubleshoot a 512K that has a bad 120V analog board.
The display keeps cutting out every half a second or so and it makes the dreaded flup flup noise. It happened out of the blue and when it's starting to get hot. The dead Mac scrolls points to bad CR20 & CR21 Schottky diodes.
I tested them but I am not getting the same results as Larry Pina... CR20 should be 31Ω/30Ω. I'm getting 107Ω/84Ω. CR21 should be 52Ω/53Ω and I'm getting 41Ω/43Ω. I got those readings by switching the red/black terminals on the multimeter between the cathode and the diode. Is that how I'm supposed to test them? Shout I try when they're hot or cold? And can you really test diodes in-circuit?
Thanks!
Thanks!
