366mhz ibook
30pin
Picked up an "as is for parts" ibook. It had some moisture stains between the plastic and metal shielding on both top and bottom of the base. Condensation or actual water had been inside the base unit. There is no green light when you push the power button on and the battery is totally dead, but it does boot with chimes.. I added ram, but it did not see it. I cleaned the ram slot with alcohol. That helped. I put a fresh install of O.S.9.2. I added an airport card. So it seems to be running fine now. 192mb of ram,and a 6gb harddrive.
slimac55
Cool, I've always liked the design of the original iBooks. I've got a whole bunch of them currently. I'll be selling all except one that I'll keep for myself.
30pin
The ibook did not come with one. I used one from another powerbook.
It is nice when some of the parts will interchange!
slimac55
Any FireWire iBooks?
I have 2 Indigos (one that I'll be keeping and one that I'll be selling). I'll post it in the Trading Post section if people are interested.
