CelGen
I've always insisted the SCSI2SD was an overpriced piece of garbage, much to the opposition of other folks too wimpy to use real hard drives. Sure it gives you a SCSI disk using an SD card but that's about it and skill wise it's prohibitive for the average person to assemble because of the number of SMD components. Also there was likely going to be better solutions. Something smaller but much more feature packed. Something to tell the SCSI2SD to get bent.
Now there is. >>>LINK<<<
It's so much better than the SCSI2SD. The link above goes over the details of the project, includes the code to set it up, additional documentation and the board layout so you can get a few fabbed and YES, you CAN solder this one together yourself and it's not a SMD nightmare. It's through-hole!
This is something I'm willing to put my weight behind. There is also the possibility of later a version for substituting the 2.5" SCSI disks in the Powerbooks. THAT holds some serious merit as it can then also be used in some of the other non-IDE laptops from the likes of RDI and IBM.
[David Kuder]’s tiny SCSI emulator is designed for just this purpose. [David] has combined a Teensy 3.5 with a NCR5380 SCSI interface chip to build his device. With a 120MHz clock and 192K of RAM, the Teensy provides plenty of horsepower to keep up with the SCSI signals, and its DMA features don’t hurt either.
Now, many earlier SCSI emulation or conversion projects have purely focused on storage – such as the SCSI2SD, which emulates a SCSI hard drive using a microSD card for storage. [David]’s pulled that off, maxing out the NCR5380’s throughput with plenty to spare on the SD card end of things. Future work looks to gain more speed through a SCSI controller upgrade.
But that’s not all SCSI’s good for. Back in the wild times that were the 80s, many computers, and particularly the early Macintosh line, were short on expansion options. This led to the development of SCSI Ethernet adapters, which [David] is also trying to emulate by adding a W5100 Ethernet shield to his project. So far the Cabletron EA412 driver [David] is using is causing the Macintosh SE test system to crash after initial setup, but debugging continues.
