ExplorerZ
Having more trouble. How do I get it through the back? The wire makes it so it can’t get fully throughErm, no. Measure from the /back/ of the connector with it plugged into the board and it powered on.
Fair point. I was in 8100 mode. The connector is more accessible on some models.Having more trouble. How do I get it through the back? The wire makes it so it can’t get fully through
The monitor I ordered is coming today. I will be able to see soon whether it displays anythingFair point. I was in 8100 mode. The connector is more accessible on some models.
I'll leave it to someone else to suggest a safe way of doing it, because I can't think of one I'm willing to suggest to you.
That will be good. Helpful to see if you're getting any output.The monitor I ordered is coming today. I will be able to see soon whether it displays anything
The battery is new, it outputs 3.6v. No I haven’t tried to boot without the battery.What are the voltage readings from the battery? Have you tried booting without the battery installed?
Booting without battery has no change. The monitor was delayed and will be arriving today instead.The battery is new, it outputs 3.6v. No I haven’t tried to boot without the battery.
View attachment 55364View attachment 55365The monitor says no signal. Any ideas? I feel like it should at least send a input.
This is the monitor. http://www1.la.dell.com/content/topics/global.aspx/snp/topics/dell-e1713s?c=bm&l=en&cs=bmbsdt1
I’m thinking about recapping the power supply.You may need to adjust those DIP switches. Try some of the settings for 640x480 or 800x600.
But it could be a marginal power supply. If there's no chime, and no video output, it is not starting.
If you have an ATX power supply, it could be adapted to TEST the machine with - but the pins are not directly compatible so you would need to map them to the 7500's power pins.
@Stinkerton18 put together a helpful guide here too https://docs.google.com/spreadsheets/d/1bKPddE9kDlInQ7N9fnO5qmQgvXjlHdIV0GcKRVskbZs/edit#gid=0
You definitely need to change the DIP switches. Your pic shows them all on, which is not a valid combination. Try each of the settings in the 13 RGB row.You may need to adjust those DIP switches.
Test with another one or an ATX one first. Not worth the effort/money to recap until you verify that's actually the problem IMO.I’m thinking about recapping the power supply.
I have a ATX from my iici, and a modern psu from my old gaming Computer. Which one do I use?Test with another one or an ATX one first. Not worth the effort/money to recap until you verify that's actually the problem IMO.
The 145 works works for my iici, but not on my pm7500.You definitely need to change the DIP switches. Your pic shows them all on, which is not a valid combination. Try each of the settings in the 13 RGB row.
You need to rewire it. The pinout isn't the same.
I just started doing things with computers. Do you have a YouTube video or a guide that could help? Thank you!You need to rewire it. The pinout isn't the same.
I'd suggest trying to borrow or buy a working 7500 PSU. Converting an ATX could lead to accidents if you're not confident.I just started doing things with computers. Do you have a YouTube video or a guide that could help? Thank you!
