chiptripper
I've been tearing my hair out troubleshooting an otherwise healthy SE/30. Adjusting brightness, either from the adjustment wheel or directly on the analog board, results in noticeable bloom (screen increases in size). When I click a menu or open a window, display shows slight horizontal shadow lines, and the left and right sides of the screen bulge slightly. If I dim the screen, the issue becomes less severe.
It has been meticulously restored. Fully recapped. Good voltages. Analog and neck board joints reflowed. I have swapped in a new flyback, new CRT, tested transistors / resistors / diodes, swapped ICs known to fail. Swapped every cable, tried different power cables, different outlets (GFCI and regular).
Probably just a random component I'm overlooking, right? Well, on a whim, I tested a non-recapped SE. It has the same issue! Then a Plus w/ recapped logic and analog board. Same! Next, Classic II I recapped years ago, has a spinning hard drive. Same.
This problem does not seem to affect my Color Classic or M1212 display. Just every B&W compact I've tested.
At this point I have to think there's an issue with mains voltage / ground in my house that these machines do not like. It's a 1950s place with two-wire outlets and (mostly) GFCIs. Does this sound plausible? Any suggestions for how to safely test this theory?
