Amon_RA
Hi,
I'm trying to repair a Color Classic for the first time, and I'm running out of ideas... so I hope someone can help me.
I got a Color Classic that according to the previous owner worked fine until it suddenly showed no more image (a few days before I picked it up).
At power-on the harddrive spins, the power led works, the fan works, but unfortunately the screen stays dark and no startup chime is sounding. I can hear the high voltage of the CRT and a slight buzzing sound at the CRT neckboard (which I guess is normal).
Some components on the analog board seem to have gotten hot over time as the PCB is showing darker spots.
There's also a connector (BV13) on the analog board that is not connected to anything, is this normal?
Things I have done so far :
* I recapped the logic board and the analog board, there were no leaking capacitors to begin with (so that's good).
* I replaced the battery with a coin cell battery (3V).
* I replaced the harddisk with a BlueScsi v2 (that works on another compact mac).
* I reflowed most contacts on the analog board just to rule out dry solderjoints.
* Removed the RAM SIMMs, just to make sure these were not causing the issue (the color classic can boot with the 4MB onboard, right?)
* Pressed the front brightness button...
None of the above actions made a difference, still no boot, no chime, and a black screen....
Does anyone have any bright ideas?
Attached some pictures of the analog and logic board.
Regards,
Bart
Regards,
Bart
