TheMightyMadman
Hi all,
I've recently got my hands on three compact Macs - a Classic and two Classic IIs.
I've got the Classic and one of the Classic IIs working well, which is great.
However, the other Classic II is putting up a fight.
Not only is the digital board not working (recapped but needs a new CPU due to corrosion), the analogue board is also faulty.
It was originally completely dead, having suffered from extremely bad capacitor leakage.
Since then, I have:
I replaced DF1 (1N4001) and DF2 (1N4148) in case there was also an issue with the vertical deflection circuit, but I suspect that this is due to the weird low-voltage supply rails; RF7 (3.3 Ohm fusible resistor) tests OK; TEA2037A has been socketed and cleaned but I don't currently have any spares.
Even though this will probably end up as a parts machine, I'd like to get it working.
Has anyone had similar symptoms, and if so did you manage to fix it? Thanks!
Many thanks,
Adam
Since then, I have:
- Replaced all of the electrolytic capacitors (except for the mains filter capacitor).
- Replaced the two RIFA-type mains filter capacitors.
- Checked power switch, fuse, and IEC connector joints - all OK.
- Replaced several parts that had been affected by leaked electrolyte:
- DP6 (MBR1045 Shottky diode), which was badly corroded.
- DP3 and DP4 (1N4148s).
- TDA4605 (PSU driver IC).
- CNY17G (optocoupler).
- QP2 IRFBC40 (output transistor).
- Desoldered and cleaned underneath most major parts, including mains transformer, flyback transformer, connectors, etc.
Many thanks,
Adam
