Apple Hard Disk 20 repair: A success story
Iesca
Saved you both the trouble!
HD20 Rodime Controller Board Electrolytic Capacitor List
C38: 47µf 16v
C41: 10µf 35v
C42: 10µf 35v
C43: 47µf 16v
C46: 10µf 35v
C48: 47µf 16v
C49: 47µf 16v
C50: 47µf 16v
Total:
3X 10µf 35v
5X 47µf 16v
(PS. I found HD Diag!)
JDW
Bless you!  But do you also know the Diameter & Height info?  (Lead Spacing is probably 2.5mm for all of them, perhaps 2.0mm.) The reason that Diameter & Height info is important is because of the required clearance.  If I find a capacitor with the same capacitance and voltage rating, the size may be different from the original and it ultimately may not fit properly or at all.  So if you have that information, could you please post it too?
On a semi-related note...
I found the following photo HERE and modified it with a couple red arrows.  What is the purpose of those two pieces contacting each other?  Is it an electrical connection?
You can see the same thing in the following 3 photos of my GCC Hyperdrive here, except mind has a broken piece of blue plastic attached which I am curious about...
