Alright, so here's (the short version of) the deal...
I was playing around with my 520c and it eventually crashed to the point of complete unresponsiveness (not that uncommon of an occurrence with this sort of machine, really). Since I kinda forgot what the force reset combo was, I tried keying it in.
Eventually, I ended up pressing Control, Option, Command, and the Power button all at once, and then the computer shut down all at once.
...and when I tried to turn it on again, nothing happened.
So I waited 6 minutes with the power disconnected and battery removed and tried again to press Ctrl-Cmd-Opt-Power (that's supposed to reset the power manager or something?). I held the keys down for what I think was around 20 seconds before trying again to boot the machine, to no avail.
Now here I am. What should I do? Currently I have two options that I can think of: remove the Backup Battery then wait a bit before reconnecting it so the computer is forced to load new Power Manager settings (more disassembly than I really want to do right now in my room), or wait an entire day or two before just trying to turn it on again.
Is it possible that I blew the fuse on the Motherboard or something? The speakers did make the sort of "sudden shutdown" noise that happens sometimes when you suddenly cut power to something, so I'm wondering about that as well.
I'm just worried I messed something up permanently by doing something in software, which isn't really an idea I like much.
